Dzisiaj jest 06 czerwca 2025, 10:38
ELD.gg-What It Really Takes to Win on Ultimate in EA FC 26
Motocykl: audio
Post » 02 czerwca 2025, 08:00
When it comes to single-player challenges in EA FC 26, the Ultimate difficulty in Squad Battles remains one of the toughest tests of a player's skill, composure, and tactical depth. But can a human player-even a professional-actually outplay the AI on its hardest setting?
Redlac, a professional FC player, set out to answer that very question in a thrilling best-of-three series against Ultimate difficulty AI teams loaded with Team of the Season (TOTS) talent. What followed was a rollercoaster of skill, rage, highlights, and an unfiltered look into what it really takes to conquer the AI overlords of EA Sports FC.
Setting the Stage: The Team and the Challenge
Redlac came fully loaded. His squad wasn't just strong-it was elite. With cards like TOTY Hullet, Maldini in defense, and attacking threats such as Janola, Dway, and Usman Dembele, this was a team built to compete at the highest level. But good players don't just test their teams against average competition-they aim for the summit.
The challenge was simple: win a best-of-three against the Ultimate difficulty AI in Squad Battles using top-tier teams, specifically one featuring Bundesliga TOTS players. Each win would net 2,000 Squad Battles points-the equivalent of first place globally if done consistently. But the objective here wasn't leaderboard glory-it was pride. It was about proving that even the most scripted AI could be beaten with the right tactics and execution.
Match One: Janola and the Glitch Goal
As the whistle blew in the first game, Redlac got a taste of just how unpredictable the Ultimate AI could be. From green-timed Travela shots to pinpoint passes, the AI showed early signs of being both clumsy and god-tier, depending on its hidden scripting. Despite an early scare from Bundesliga Kane, Redlac's sharp movement and finishing gave him the edge.
Fabian Ruiz opened the scoring, and soon the floodgates opened. Janola was everywhere-scoring with pinpoint accuracy and demonstrating why his EVO upgrades made him one of the most lethal forwards in FC 26. The AI tried its tricks, but Redlac had clearly found a formula: time the greens, take the angles, and avoid sloppy buildup play.
Final score: 4-2 to Redlac. Series lead: 1-0.
Match Two: A Step Up in Difficulty
Rather than facing the same AI team again, Redlac upped the ante. His next opponent featured a five-at-the-back setup, with even more compact defense and better pressing. The challenge? Seal the series with a clean 2-0 sweep.
Things got off to a frantic start. Janola continued his heroics with a left-footed strike to the far post, showing that when he touches the ball, magic can happen. But the AI wasn't done. A pinpoint AI goal from a left-footed finesse into the top corner reminded everyone watching that Ultimate difficulty AI doesn't miss when it decides to shoot.
Extra time loomed. The score was tied, and every tackle, pass, and keeper movement became life or death. When penalties hit, Redlac knew he was in trouble. "They know where I'm going," he said nervously before diving late on each AI shot.
Despite some big saves and tactical dives, it wasn't enough. The AI took the shootout. Series tied 1-1.
Match Three: The Decider
After a humbling defeat in penalties, Redlac faced the Bundesliga TOTS squad again for a final showdown. This wasn't just about winning anymore-it was about regaining control, proving the first match wasn't a fluke, and sealing the series for good.
It started hot. Yellow-timed finishes from Janola and slick passing combinations gave Redlac the upper hand early. He surged ahead 2-1, then 4-2, dominating possession and exploiting the AI's delayed reactions and occasional bad positioning.
Even with the AI responding with "aimbot" goals that defied keeper movement and logic, Redlac stayed composed. Another Janola screamer and a smart through ball led to a 5-3 final score. Series won 2-1.
Mission accomplished.Key Takeaways: Can You Beat Ultimate Difficulty?
Redlac's victory wasn't just about having a great team-it was about understanding the mechanics, knowing when to time shots, and being disciplined in defense. Here are the key lessons:
1.Green Timing is Everything
Nearly every one of Redlac's goals came from green-timed shots. Ultimate AI keepers have unnatural reflexes, but green timing gives your shots just enough edge to beat them.
2.AI Has "Momentum" and Aimbot Moments
Redlac highlighted how the AI can feel scripted-sometimes they're clumsy and slow, and other times they'll pull off double skill moves and rocket shots that even manual keepers can't stop. Recognizing these patterns helps avoid frustration.
3.Adapt Your Gameplan
Switching opponents and adapting to different formations (e.g., five-at-the-back) helped Redlac stay ahead. Don't rely on just one way to attack-Ultimate AI punishes predictability.
4.Play with EVO Players
Janola's EVO upgrades turned him into a world-beater. If you want to beat the best AI, you need players who can dribble, finish, and outplay defenders on their own.
5.Set Pieces Are Crucial
From corners to free kicks, Redlac tried to exploit AI weaknesses. While success varied, set pieces often led to chaos in the box, which can be converted into goals against the AI.
Final Thoughts: Is Ultimate AI Actually Fair?
One recurring theme across all three games was the inconsistency of the Ultimate AI. In some moments, it would misplace passes or leave space open. In others, it became nearly invincible-defenders auto-tracking runs, keepers making impossible saves, and attackers scoring from absurd angles.
This inconsistency can be maddening, but it's also what makes Squad Battles on Ultimate engaging. It's a mental battle as much as a mechanical one. You have to stay focused, avoid tilt, and keep adapting to the AI's rhythm shifts.
In Redlac's case, he not only beat the Ultimate AI-he exposed its limits. Yes, it's possible to win. But you'll need every advantage: elite players, EVO upgrades, green timing, and maybe a little luck.
Conclusion: Ultimate AI Has Met Its Match
Redlac's journey through a best-of-three against the most difficult AI in EA FC 26 was a thrilling reminder that even in a game with scripted difficulty and unpredictable behavior, skill still matters. With smart tactics, elite players, and a bit of grit, the so-called "invincible" AI can be humbled.
So if you've ever been cooked by a left-footed finesse from a bronze player or seen your keeper beaten by a random green rocket, just know-it happens to the pros too. But with the right approach, you can come out on top.
Get FC 26 Coins (FC Coins) from ELD.gg – the world's first automated platform with a SMART ANTI-BAN system. Enjoy fast delivery, 24/7 support, and full platform compatibility!
