While the Sceptre is one of the best choices for Spirit-enhancing gear, some other equipment pieces also provide smaller bonuses to <a href="https://www.mmoexp.com/Poe-2/Currency.html">POE 2 Currency</a> Max Spirit. These bonuses are typically indicated by a "+x Spirit" stat. However, they are much rarer compared to the Sceptre, making it a must-have for players who rely on Spirit.
Passive Skill Points and Ascendancy Nodes
As you level up, you can allocate Passive Skill Points to enhance your Max Spirit or improve the efficiency of Spirit reservation. Many Passive Skill Nodes are designed to either increase your Max Spirit or reduce the Spirit reservation cost for certain abilities, allowing you to use more Spirit-heavy skills without running out of resources.
In addition to Passive Skill Nodes, Ascendancy Nodes can also provide powerful Spirit-related benefits. For instance, the Infernalist Witch Ascendancy node "Beidat's Will" increases your Max Spirit based on your Max Life, creating a synergy between your health and Spirit capacity. This can be especially useful for builds that focus on both high Life and Spirit pools.
Balancing Spirit with Life and Mana
While increasing your Max Spirit is crucial for Spirit-reliant builds, it’s important to maintain a balance between your Life, Mana, and Spirit pools. Focusing too heavily on one resource can leave your character vulnerable, especially in high-stakes combat situations.
For Minion Witch builds or any setup that requires a significant amount of Spirit, equipping a Sceptre early on can make a noticeable difference. Once your build progresses and you begin acquiring more Spirit bonuses through bosses, gear, and Passive Skill Nodes, you can eventually phase out the Sceptre in favor of other more versatile weapons. However, for builds that heavily depend on <a href="https://www.mmoexp.com/Poe-2/Currency.html">buy POE 2 Currency</a> Spirit, maintaining a high Max Spirit remains essential to maximizing your abilities.
