Elden Ring: 14 Runes Mistakes You Should Avoid at All Costs
In Elden Ring, runes are more than just currency—they’re the lifeblood of progression. Whether you’re leveling up, upgrading gear, or stocking up on consumables, every rune matters. But even seasoned Tarnished make costly mistakes when it comes to rune management. If you're serious about surviving The Lands Between, here are 14 rune-related mistakes you absolutely must avoid.
1. Failing to Bank Your Runes Before Exploring
One of the most painful lessons comes from losing tens of thousands of runes to a random death. If you’re heading into unknown territory—especially catacombs or legacy dungeons—bank your runes at a Site of Grace first. Don’t get greedy.
2. Ignoring Rune-Boosting Talismans
Talismans like the Gold Scarab can significantly boost rune gain from enemies. Many players overlook these items early on, missing out on thousands of runes over time. Equip them during farming sessions or boss runs to maximize efficiency.
3. Underestimating Enemy Rune Yields
Not all enemies are created equal. Some mobs, especially in endgame zones, drop absurd amounts of runes. If you're still farming weak enemies in Limgrave, it's time to reassess your strategy.
4. Overcommitting to Rune Farming Without Upgrading Gear
Farming is important, but not if your weapon is still +3 when it could be +9. Diverting all your runes to leveling without reinforcing your armaments creates a power gap that only grows wider. It’s smarter to balance investment in both stats and equipment.
5. Farming Inefficiently Without Buffs
Many players farm without using Gold-Pickled Fowl Foot, which temporarily boosts rune acquisition. These consumables are easy to craft and can make a huge difference when used consistently. If you're going to grind, do it right.
6. Risking Runes in Co-op or PvP
Diving into multiplayer with a full wallet of runes is a recipe for regret. While co-op can be rewarding and PvP thrilling, it’s best to store your runes before summoning or being summoned.
7. Not Using Runes on Essential Purchases
Some players hoard runes without realizing that critical upgrades are locked behind merchants. Don’t wait too long to buy Elden Ring Items:https://www.u4gm.com/elden-ring-items like smithing stones, sacrificial twigs, or crafting recipes. If you’re not spending, you’re stalling.
8. Skipping Rune Farming Hotspots
Areas like Mohgwyn Palace and the Haligtree offer some of the best rune yields in the game. If you haven’t unlocked them, it’s worth doing so just for the farming potential. Don’t restrict yourself to low-efficiency zones.
9. Forgetting to Recover Lost Runes
It sounds simple, but too many players abandon their lost runes out of frustration or laziness. If they’re recoverable—go get them. Even if it means stealthing back through a dangerous zone, it’s often worth the effort.
10. Ignoring Rune Efficiency in Builds
Not all builds are rune-efficient. For example, hybrid builds often require more stat investment, which can delay your power curve. If you’re rerolling or planning a new character, consider how much rune investment your build truly needs.
11. Not Selling Unused Equipment
Your inventory probably holds dozens of items you’ll never use. Selling off old weapons, armor, or duplicates is an underrated way to earn some quick runes. Even if you later buy Elden Ring runes:https://www.u4gm.com/elden-ring-runes, this is a clean way to generate extra funds.
12. Losing Runes in Platforming Zones
Places like Nokron or Deeproot Depths are notorious for killing players with gravity. If you're exploring areas with risky jumps, spend your runes first. Falling to your death with 60k in your pocket is a soul-crushing mistake.
13. Mismanaging Rune Arcs and Buffs
Rune Arcs can grant you a serious edge when exploring or fighting bosses, but using them recklessly means burning resources. Wait until you're confident in a fight before activating these buffs, especially if you’re short on them.
14. Neglecting Alternative Rune Sources
Not all runes come from combat. Completing NPC quests, discovering hidden chests, or defeating invaders can all offer rune rewards. Don’t limit yourself to brute-force farming—there are smarter, safer ways to build your bank.
Final Thoughts
Runes are too valuable to waste. Whether you're a new Tarnished or a returning veteran, being mindful of how you gain—and lose—runes can shape your entire Elden Ring experience. If you’re struggling, don’t hesitate to buy Elden Ring runes or buy Elden Ring Items from trusted sources to ease the grind. Just make sure you avoid these mistakes first—you’ll thank yourself later.
Final Thoughts
