Dzisiaj jest 06 lipca 2025, 08:06
Elden Ring: 16 Runes Farming Spots You Shouldn’t Miss
Elden Ring Items
Motocykl: Scooter
Post » 05 lipca 2025, 09:28
If you’ve spent any time in Elden Ring, you know that runes are the lifeblood of character progression. Whether you’re leveling up, buying essential gear, or crafting materials, having a steady supply of runes is crucial. While exploring the vast world of the Lands Between is rewarding, sometimes you need a reliable spot to farm runes efficiently. Here are 16 rune farming locations that every player should know about.
1. Gatefront Ruins
Early in the game, Gatefront Ruins offers a decent number of soldiers that drop a fair amount of runes. Perfect for low-level players looking to get a solid start.
2. Stormhill
This area has several groups of enemies that can be cleared quickly. The density of enemies here makes it great for rune farming once you have some combat skills.
3. Mistwood
This forested area contains some tough enemies, but they drop a good number of runes. Just be careful with ambushes.
4. Caelid’s Smoldering Wall
If you’ve made it this far, enemies here drop higher runes. They can be tough, but the payoff is worth it.
5. Sellia Crystal Tunnel
A bit later in the game, this tunnel has groups of crystal enemies that can be farmed repeatedly with proper AoE attacks.
6. Academy Gate Town
Lots of magic users and soldiers packed into a small area make this a great place for experienced players to grind.
7. Caelid’s Scarlet Rot Town
The enemies here give you a high rune yield, but be cautious of the Scarlet Rot status effect.
8. Altus Plateau’s Smithing Stone Farms
These enemies drop both runes and smithing stones, useful if you want to upgrade your gear as well.
9. Abandoned Cave
This cave near the Caelid area is a hidden gem for farming runes if you can handle the tougher foes inside.
10. Radagon’s Rise
Near the Leyndell area, this spot is home to powerful knights that drop substantial runes.
11. Dragonbarrow
High-level dragons and enemies that yield lots of runes, but only recommended for advanced players.
12. Deeproot Depths
A challenging area, but the enemies here have one of the best rune drops in the game.
13. Raya Lucaria Grand Library
If you can navigate this dungeon, the mages inside drop a solid number of runes and valuable items.
14. The Shaded Castle
Enemies here are tough but yield impressive rune rewards.
15. Mohgwyn Palace
A late-game location with high rune rewards. Many players come here to farm runes for their endgame builds.
16. Volcano Manor Courtyard
Packed with enemies that drop a good amount of runes, this area also offers a chance for specific loot.
If you’re ever short on runes and looking for a shortcut, you might hear about players who turn to elden ring runes for sale or even an elden shop to help boost their rune stock quickly. While some prefer grinding through these spots, others consider alternative ways to gain runes faster, especially if they want to experiment with builds without the grind.
Rune farming is all about balancing risk and reward. The spots above cover a wide range of difficulty levels and areas, so whether you’re a fresh Tarnished or an experienced Elden Lord, you can find a place that suits your current needs.
Remember, patience is key. Farming runes might sometimes feel tedious, but it’s part of what makes progression satisfying. Try to mix farming runs with exploration and boss fights to keep the experience fresh.
So grab your weapon, prepare your spells, and head out to one of these spots. Your next level-up or upgrade is just a few rune drops away.
